guys,
does anyone know if there is a typing shortcut for the osnap "midway between two points"
i know there are shortcuts for others like perpendicular- per
or intersection- int
etc etc..
cheers.
S
midpoint between two points: mtp or you can also use m2p.
thanks alot ReMark :)
Another way would be to hold down the ctrl key and right click, the object snap options will come up, select midway between 2 points.
  • 2 weeks later...
or shift + ryt click gives u same result
thats the one i had been using until ReMarks post i use MTP now ;)
cheers
I've re-assigned my F1 key to activate M2P
Since I'm still half addicted to buttons and toolbars (at least for Osnaps anyway) I created a custom button. Simplest macro I've ever done, _m2p
