Small Fish Posted June 5, 2009 Posted June 5, 2009 Just when I thought I was adding the finishing touches to my code, I now have a flaw, that has driven me insane! I guess I have asked Lee mac my share of questions. Perhaps Wizman can help me out as he gave me the code to sort circle rows(along with Lee mac) Wizman did the sorting but Lee mac sorted them in the right order, and this what I am finding so hard to achieve, amending it to suit. A vertical line divides the rows of circles. As I said I want to have a Final List that gives For example- FinalList=((1 (5.0 5.0 5.0)(2(3.0 3.0)(3(8.0 8.0 8.0)) where row 1 has 3 circles of 5.0 radius, row 2 has 2 circles of 3.0 radius etc I would like a 'FinalList' for the right side and a 'FinalList' for the left side of the line. At the moment I can't get any list. Please help I am going insane trying to make work! thank you Here is the code that I have so far: (defun c:RowAreas (/ lent ldat ss tcirc subss total test subss_lst clst rad flag new_xxlst listrowdia finallist subss_lst Rad areaobj cLst jsx_ename dxf_ent) (vl-load-com) (if (and (setq lEnt (car (entsel "\nSelect Vertical Line: "))) (eq "LINE" (cdadr (entget lEnt)))) (progn (setq lDat (list (cdr (assoc 10 (entget lEnt))) (cdr (assoc 11 (entget lEnt))))) (princ "\n\nLEFT:\n") (repeat 2 (setq test 1) (if (setq ss (ssget "_X" (list '(0 . "CIRCLE")(cons -4 (if flag ">=,*,*" "<=,*,*")) (cons 10 (append (list (apply (if flag 'max 'min) (mapcar 'car lDat))) '(0 0)))))) (while (not (zerop (sslength ss))) (setq dxf_ent (entget (setq jsx_ename (ssname ss 0)))) (setq tCirc (ssname ss 0)) (if (setq subSs (ssget "_X" (list (cons 0 "CIRCLE") (cons -4 (if flag ">=,=,*" "<=,=,*")) (cons 10 (append (list (apply (if flag 'max 'min) (mapcar 'car lDat))) (cddr (assoc 10 (entget tCirc)))))))) (progn (setq total 0.0) (foreach ent (setq new_xxlst (mapcar 'cadr (ssnamex subSs))) (setq areaobj (vla-get-area (vlax-ename->vla-object ent)) total (+ total areaobj)) );foreach (setq cLst (vl-sort (mapcar '(lambda (x) (cdr (assoc 10 (entget x)))) new_xxlst) '(lambda (x1 x2) (< (car x1) (car x2))));centrepoint Rad (vl-sort (mapcar '(lambda (x) (cdr (assoc 40 (entget x)))) new_xxlst) '(lambda (r1 r2) (> r1 r2))));radius (setq ListRowDia (cons (append (list (caddr (assoc 10 (entget (car new_xxlst))))) Rad) ListRowDia)) (mapcar '(lambda (x) (ssdel x ss)) new_xxlst) );progn );if (ssdel jsx_ename ss) );while (foreach x (mapcar 'cdr (vl-sort ListRowDia '(lambda (x1 x2) (< (car x1) (car x2))))) (setq test 1) (setq FinalList (cons (list test x) FinalList) test (1+ test)) );foreach );if (and (not flag) (princ "\n\nRIGHT:\n")) (setq flag T) );repeat );progn (princ "\n<!> No Line Selected <!>") );if-->for dividing line (princ (vl-princ-to-string FinalList)) (princ ) );defun Quote
wizman Posted June 5, 2009 Posted June 5, 2009 Please try: (defun c:RowAreas (/ lent ldat ss tcirc subss total test subss_lst clst rad flag new_xxlst listrowdia finallist subss_lst Rad areaobj cLst jsx_ename dxf_ent) (vl-load-com) (if (and (setq lEnt (car (entsel "\nSelect Vertical Line: "))) (eq "LINE" (cdadr (entget lEnt)))) (progn (setq lDat (list (cdr (assoc 10 (entget lEnt))) (cdr (assoc 11 (entget lEnt))))) (princ "\n\nLEFT:\n") (repeat 2 ;(SETQ TEST 1);;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (if (setq ss (ssget "_X" (list '(0 . "CIRCLE")(cons -4 (if flag ">=,*,*" "<=,*,*")) (cons 10 (append (list (apply (if flag 'max 'min) (mapcar 'car lDat))) '(0 0)))))) (PROGN;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (while (not (zerop (sslength ss))) (setq dxf_ent (entget (setq jsx_ename (ssname ss 0)))) (setq tCirc (ssname ss 0)) (if (setq subSs (ssget "_X" (list (cons 0 "CIRCLE") (cons -4 (if flag ">=,=,*" "<=,=,*")) (cons 10 (append (list (apply (if flag 'max 'min) (mapcar 'car lDat))) (cddr (assoc 10 (entget tCirc)))))))) (progn (setq total 0.0) (foreach ent (setq new_xxlst (mapcar 'cadr (ssnamex subSs))) (setq areaobj (vla-get-area (vlax-ename->vla-object ent)) total (+ total areaobj)) );foreach (setq cLst (vl-sort (mapcar '(lambda (x) (cdr (assoc 10 (entget x)))) new_xxlst) '(lambda (x1 x2) (< (car x1) (car x2))));centrepoint Rad (vl-sort (mapcar '(lambda (x) (cdr (assoc 40 (entget x)))) new_xxlst) '(lambda (r1 r2) (> r1 r2))));radius (setq ListRowDia (cons (append (list (caddr (assoc 10 (entget (car new_xxlst))))) Rad) ListRowDia)) (mapcar '(lambda (x) (ssdel x ss)) new_xxlst) );progn );if (ssdel jsx_ename ss) );while (SETQ TEST 1);;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (foreach x (mapcar 'cdr (vl-sort ListRowDia '(lambda (x1 x2) (< (car x1) (car x2))))) (setq FinalList (cons (list test x) FinalList) test (1+ test)) );foreach (PRINC (VL-PRINC-TO-STRING FINALLIST))(SETQ FINALLIST NIL LISTROWDIA NIL);;;;;;;;;;;;;;;;;;;;;;;;;;;;; );PROGN;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; );if (and (not flag) (princ "\n\nRIGHT:\n")) (setq flag T) );repeat );progn (princ "\n<!> No Line Selected <!>") );if-->for dividing line (princ ) );defun Quote
Small Fish Posted June 5, 2009 Author Posted June 5, 2009 Hey thanks Wizman! I am very pleased! :-) Just one other question how can I make 2 sets outside of the 'while'- one for the right and one for the left? cheers S.F. Quote
wizman Posted June 5, 2009 Posted June 5, 2009 Hey thanks Wizman!I am very pleased! :-) Just one other question how can I make 2 sets outside of the 'while'- one for the right and one for the left? cheers S.F. you're welcome small fish, im not sure i get your next question, maybe you just need another variable to store left and right. *edit2 *deleted wrong comment on princ* Quote
Small Fish Posted June 5, 2009 Author Posted June 5, 2009 yes that is what I was trying to ask - how can I make a variables for both left and right sets? If I take away the PRINC it does show any list.... Quote
wizman Posted June 5, 2009 Posted June 5, 2009 sorry for confusing, you're right princ needs to be there. Quote
wizman Posted June 5, 2009 Posted June 5, 2009 Add the red line for global variable LEFT and RIGHT...:-) .............................................................. );if (ssdel jsx_ename ss) );while (SETQ TEST 1) (foreach x (mapcar 'cdr (vl-sort ListRowDia '(lambda (x1 x2) (< (car x1) (car x2))))) (setq FinalList (cons (list test x) FinalList) test (1+ test)) );foreach (PRINC (VL-PRINC-TO-STRING FINALLIST)) [color="Red"](SET (IF FLAG 'RIGHT 'LEFT) FINALLIST)[/color] (SETQ FINALLIST NIL LISTROWDIA NIL) ) );if (and (not flag) (princ "\n\nRIGHT:\n")) (setq flag T) );repeat );progn (princ "\n<!> No Line Selected <!>") );if-->for dividing line (princ ) );defun Quote
Small Fish Posted June 6, 2009 Author Posted June 6, 2009 thanks for your time Wizman - that's just what I wanted. One headache gone :-) cheers Small Fish Quote
