dundeeslugger Posted June 8, 2009 Posted June 8, 2009 So for example I am trying to make a door marker annotative block. I define my text attributes and make a circle around the text. I then make the block. If I make the block with retain selected and insert the block in a file the block functions correctly except the circle does not scale annotatively. If I make the same block but have convert to block checked the block scales correctly but I have to explode the block in order to change the text attribute. What's the deal? Quote
MaxwellEdison Posted June 8, 2009 Posted June 8, 2009 Having a rough time parsing exactly what you're saying. Can you upload an example of what you have so far? Quote
dundeeslugger Posted June 8, 2009 Author Posted June 8, 2009 Having a rough time parsing exactly what you're saying. Can you upload an example of what you have so far? Ok, forget that problem. Here is my new problem. When I create an Annotative block, and change the scale the block not only changes scale but it moves. Quote
MaxwellEdison Posted June 8, 2009 Posted June 8, 2009 Sounds like the whole thing is scaling off of the base point. Double check that the base point is the same place you would want the block to scale from if you did it manually. Quote
