Jacko93 Posted June 9, 2009 Posted June 9, 2009 The cadduct viewer is a little more stable than MEP. However, I have noticed that if you redifine a block within your drawing, it will still show the old block representation in the Cadduct viewer. I figure that this is due to the viewer working off a cache, which would explain the stability of it. However, it means that clash checks don't always ring true. My question is, is there a way to update the cache in Autocad without having to shutdown and open the drawing again? That is the only way I have figured out to update the Cadduct viewer. Quote
