I am trying to use this in a lot of routines so I don't have to retype it all the time. But when the getin functions is call it is not setting the values. What am I doing wrong?
(defun getin (/ OSM LAY)
(setvar "CMDECHO" 0)
(setq
 OSM (getvar "OSMODE")
 LAY (getvar "CLAYER")
);end setq
(setvar "OSMODE" 0)
);end defun
(defun getout ()
(setvar "CMDECHO" 1)
(setvar "OSMODE" OSM)
(setvar "CLAYER" LAY)
);end defun
Thanks for any help!!
Getin works, but you're setting the variables OSM and LAY to local, which means when the function is done, those values are set to nil. Thus, when you try to call getout, it's trying to set the system variables "OSMODE" and "CLAYER" to nil.
when you kill your variables (/ osm lay) in the getin function it makes them nil when the function ends so when the getout function is called the variables osm and lay are nil. so kill the variables in the main lisp function
look into error trapping and develop a global error trap to use.
Thanks I think I was thinking backwards on the local and global thing.
Thanks again works fine.
