Is there a command that will count how many times a block is used within a drawing?
not sure if there is one but pretty sure a lisp could do it
When I try BCOUNT it only counts the block I click on as 1. Isn't there a command that will count all of the uses of that one block. I know my speaker symbol is used approx 150+ times.
Press ENTER when AutoCAD prompts you for a block. It will count *all* of them
Watch the command line, after starting BCOUNT simply type ALL, enter.
If that is not enough for you: use a Lisp to count the clicked blocks, save their insertion points and attributes in an Excel file.
or you can QSELECT the block with its name, then go to the properties palette and it will show you how many are selected.
