cayoub Posted June 15, 2009 Posted June 15, 2009 I'm having difficulty getting my drawing to print with multiple line weights. If I select a line and go format line weights it's automatically chaning all the other lines int eh drawing to have that same line weight and not just the one I selected. I even tried creating new layers with different lineweights and it still all printed the same. Please help! Quote
Seanfts Posted June 15, 2009 Posted June 15, 2009 Does the lineweight shows the same when viewing in AutoCAD or it is just printted in same lineweight? Does it occurs on all of your drawings? If it is about printting, you can define new CTB file and load the customized CTB when plotting. (Enter 'options' in command line of AutoCAD, 'Plot and publish' tab click on 'plot style table settings', choose one from 'current plot style table setting' or click on 'add or edit plot stytle table' to create a new one.) --- Sean AutoDWG Quote
