I always have troubles entering attributes into blocks, any simple tips please
What exactly do you mean by troubles?
What I usually do is just have the properties toolbar open so that when I select a block I can see all the attributes and punch them in that way. As opposed to double clicking each block and changing it in the attribute editor.
Not sure if that is what you are looking for or not...
Are you having trouble creating a block that has attributes?
No its not actually creating the block, its remembering what is TAG, what is PROMPT etc
TAG=name that identifies the attribute. Example: ID
PROMPT=message displayed when you insert the block. Example: What is employee's ID number?
In some cases a person may elect to make the Tag and the Prompt similar.
