ulticad man Posted June 16, 2009 Posted June 16, 2009 can some one help me wit a scaling issue be cause im going to get fired 1/100 is the only scale that works for me .and getting it to work i have to zoom (enter)scale (enter) 0.01XP and that works this is all in paper space by the way . Quote
Tiger Posted June 16, 2009 Posted June 16, 2009 Hey Ulticad, and welcome to the forum. I have moved your question to it's own thread, you'll get better responses that way and keeps the order in the forum. In the future, please start a new thread for each new question. As for your question, are your Viewports locked? What happens when you try another scale? Quote
rkent Posted June 16, 2009 Posted June 16, 2009 I am not sure what you question is but I will guess. If you want to do the vp scale another way, 1:100 can also be zoom, 1/100XP so 1:50 = zoom, 1/50XP or 1:10 = zoom, 1/10XP or 1/4"=1'-0" = 1/48XP (1/4 = .25, 12/.25 = 48) Hope that helps. Quote
MaxwellEdison Posted June 16, 2009 Posted June 16, 2009 You can also use SCALELISTEDIT to go in and respecify your available scales. Quote
rkent Posted June 16, 2009 Posted June 16, 2009 You can also use SCALELISTEDIT to go in and respecify your available scales. It has been a while since I used 2004 so I wasn't sure that was available then, if it is then that is the way to go. Quote
ulticad man Posted June 18, 2009 Author Posted June 18, 2009 got it! thanks for the help lads but dont think ye are getting off that lightly I will be back for more . Thanks again :wink: Quote
