JWSLU Posted June 17, 2009 Posted June 17, 2009 A solid background is printed behind the text where I used text masking (in autocad2004 and 2009). Text masking works when I changed the printer driver to Canon iR c5185 H1 PCL6, but then another problem arises - certain fonts and objects of certain colors are printed very dark speciall when text width is not 1. If I used other driver, all fonts and colors are printed as they be, but text masking don't work Any help is appreciated. Quote
AVITWeb Posted June 19, 2009 Posted June 19, 2009 This sounds like a driver issue for the printer. If you have a Post Script (PS) driver for the printer in question, try that. Quote
JWSLU Posted June 19, 2009 Author Posted June 19, 2009 I was using a PS driver (Canon iR5185-H1 PS Ver2.0) when I got that problem with solid block under the textmasked text. Quote
