jkiox Posted June 19, 2009 Posted June 19, 2009 hello.please help me. i need to render a presentation output of an exterior wall that displays pure white color.i am using flat paint material for the exterior wall and attach white color in it.now when i render it, it appears gray.i have been trying to click some of the sun properties as well as the advance settings but i am still not satisfied with the result.is there any other way i can achieve an effect such as the this one photo i attach here, i am using autocad 2009 because it is more easier to manipulate 3d in it.i am in pursue of a deadline.can any one help me please.... Quote
Cad64 Posted July 17, 2009 Posted July 17, 2009 You should probably attach a render of the building you are actually working on, so we can see what's happening with your scene. Also, screenshots of your material settings and render settings would be helpful also. Unless you've already solved the problem. If that's the case, then please share your solution with us. Quote
