srhae Posted June 19, 2009 Posted June 19, 2009 Ok I'm using photometric lights (point) with Mental Ray in Max 10. The problem I am having is that my lights are reflecting as little balls of light in the glass of my cabinet doors. There are times when that might be a desired effect But in this case it is not. Is there an easy way to exclude just the reflection of the light from the glass? Thank you !! Quote
Cad64 Posted June 19, 2009 Posted June 19, 2009 Select the light and then go into the Modify panel. Under "Advanced Effects", uncheck the "Specular" option. That should get rid of the light spots. Quote
