Rooster Posted June 25, 2009 Author Posted June 25, 2009 It all works fine for me, which command is it saying is unknown? ok - i seem to have got it going without the error message now. next problem (!): when i use the fts lisp within a script that i run, i use it to select all text with 'standard' text style (which is what fts does) and then change the text style of these to my own style like so: FTS (enter) ALL (enter) (enter) CHT (enter) S (enter) (enter) LDS_TEXT (enter) when running fts within this new lisp, how can i get it to do everything from 'ALL' onwards? Quote
Lee Mac Posted June 25, 2009 Posted June 25, 2009 This will make FTS select all text items with Standard style: (defun c:fts (/ cSet) (if (setq cSet (ssget "_X" '((0 . "*TEXT") (7 . "Standard")))) (progn (princ (strcat "\n" (rtos (sslength cSet) 2 0) " found.")) (sssetfirst nil cSet)) (princ "\n<< Nothing found >>")) (princ)) (defun c:test () (c:fts) (princ)) Quote
Rooster Posted June 25, 2009 Author Posted June 25, 2009 This will make FTS select all text items with Standard style: i thought it was already doing that? my problem was then in using the selection & changing it to a different text style as i would do in my script.... Quote
Lee Mac Posted June 25, 2009 Posted June 25, 2009 i thought it was already doing that? my problem was then in using the selection & changing it to a different text style as i would do in my script.... In the previous posted version, the user would have to select the text items manually. Quote
Rooster Posted June 25, 2009 Author Posted June 25, 2009 In the previoud posted version, the user would have to select the text items manually. ah - i see! thanks - i think that helps me with my next step. much appreciated as always, lee Quote
gilsoto13 Posted August 14, 2009 Posted August 14, 2009 untested, but this should work: (defun c:TEST (/) (or c:SPL2PL (load "SPL2PL")) (vla-sendcommand (vla-get-activedocument (vlax-get-acad-object) ) ;_ vla-get-activedocument "SPL2PL all 0.1 " ) ;_ vla-sendcommand (princ) ) ;_ defun I never thought it was possible... Tested and works... let's automate all of our lisps. Quote
Lee Mac Posted August 15, 2009 Posted August 15, 2009 I never thought it was possible... You should know by now... anything is possible Quote
alanjt Posted August 15, 2009 Posted August 15, 2009 You should know by now... anything is possible here at cadtutor, we make your wildest dreams come true. Quote
Lee Mac Posted August 15, 2009 Posted August 15, 2009 here at cadtutor, we make your wildest dreams come true. I think you forgot the tags... Quote
alanjt Posted August 15, 2009 Posted August 15, 2009 I think you forgot the tags... the sleepy guy was the best i could do. i didn't like the eye rolling one. Quote
TheyCallMeJohn Posted December 5, 2013 Posted December 5, 2013 Is there a way though to call another lisp command when the first lisp finishes or a way to make the lisp quit and call another one. (Sorry to hijack the thread but there are several already with almost the exact same title...) Quote
MSasu Posted December 6, 2013 Posted December 6, 2013 call another lisp command when the first lisp finishes Do you have access to the code? If yes, then just add a call statement at its end: (defun MyFunction1st() ... [color=magenta] (MyFunction2nd) ;add call to second function[/color] (princ) ) Other: (defun MyFunction3rd() (MyFunction1st) ;call first function (MyFunction2nd) ;call second function (princ) ) Or, maybe, take a look to reactors. make the lisp quit and call another one. Can you give us more details on this? You are looking to call the second function instead of first? For this case, if the symbol isn't protected, redefine it: (defun MyFunction1st() (MyFunction2nd) ;call second function (princ) ) Quote
