nyaromulo Posted June 23, 2009 Posted June 23, 2009 Using Civil 3D 2009: What is the easiest way to turn off layers within "x-ref" view port? I brought all my x-ref drawing on layer-0 thank you nyaromulo Quote
rkent Posted June 23, 2009 Posted June 23, 2009 Using Civil 3D 2009: What is the easiest way to turn off layers within "x-ref" view port? I brought all my x-ref drawing on layer-0 thank you nyaromulo With the viewport active, start the layer manager, select the Xref filter, pick the xref under that, pick on any layer, select all with shift-a, go over to the right to find the vplayer column and hit the freeze/thaw icon. Quote
