Spiderguy Posted June 24, 2009 Posted June 24, 2009 Hello! I have a problem with Adobe (imagine that). OK, I used the wipeout comand to clear out hatch, lines and objects with out having to trim them for section/ detail cut bubles. Works great to plot, looks great on the screen in a PDF, however, if a plot has to be made from a PDF - everywhere there is a wipeout "spot" used is black. Has anyone else had this problem? Is there a fix for it, I would much rather use this comand instead of triming and having to explode then trim blocks. There are a multitude of reasons why this is the best way to go with clearing the background if this problem can be fixed! I use background mask when appropriate, however, there is a couple of issues with that, however, it does work great with text. Thanks, Matt Quote
Danse_Macabre Posted June 24, 2009 Posted June 24, 2009 I have had this exact same problem only it was while I was using background masks. Unfortunatly I never figured out what the problem was. One thing I just thought of though, I am guessing you have your CAD background set to black? Try changing it to white in options before you plot the PDF, maybe it will do the trick for you. Other than that, I dont really know what to try. Quote
EMS_0525 Posted June 24, 2009 Posted June 24, 2009 i have had the problem also... i just put the wipeout command out of my mind, couldnt fix it. try a different pdf driver to print. I have also had that issue with different kinds of images. Quote
Spiderguy Posted June 24, 2009 Author Posted June 24, 2009 I would like to get it to work if I can, it solves a lot of issues, if this can be averted! Quote
qball Posted June 24, 2009 Posted June 24, 2009 Plotter Driver as EMS_0525 said. I use PDF-Xchange for Acroplot. Haven't had that problem. And the blueprinter we use uses Kip products I think. And our 11x17's go on HP5100. Wipeouts never print black. Check with your driver supplier. Quote
Spiderguy Posted June 25, 2009 Author Posted June 25, 2009 the wipeouts only print black when plotting from the PDF's. If plotted from AutoCAD to the plotter they are fine. When veiwing the PDF's on screen, they look fine. Quote
wannabe Posted June 25, 2009 Posted June 25, 2009 Install the Postscript system plotter (Autodesk ePlot). It can appreciate Wipeouts at the compromise of increased file size. Or you could use textboxes with masked backgrounds instead. Tools --> options --> plot and publish --> Add Printer Quote
Spiderguy Posted June 26, 2009 Author Posted June 26, 2009 background mask doesn't work for section cut bubles - her in lies the problem, also with background mask you have to fool around with it or the box to get the area masked and box to fit. Wipeout takes care of that. I will try the ePlot, Thanks. Quote
hazardman Posted June 26, 2009 Posted June 26, 2009 it's a known issue with *.pdf printers...in general i don't have this problem using acrobat pro... a workaround is to plot to a dwf first then print that to a pdf... Quote
RFRUSSO Posted June 26, 2009 Posted June 26, 2009 I use Bluebeam to PDF my drawings. We got it because of this e=very issue. It costs about $200 or some thing but it will work on your wipeouts and it is also great for when you need to batch plot your drawings to PDF. Quote
Spiderguy Posted June 29, 2009 Author Posted June 29, 2009 I use the sheet set manager to batch plot, does a wonderful job. I will try these and let you know what I find out! Thanks! Matt Quote
summer13 Posted December 7, 2009 Posted December 7, 2009 I make a layer called "wipeout" and set the color to 255,255,255 and put all wipeouts & textmasks on this layer. Then when you print from the PDF, the black blobs won't appear. Quote
Spiderguy Posted December 7, 2009 Author Posted December 7, 2009 Thanks, we are in a period of transition with ACAD 2010 - also getting Bluebeam, hope some things have changed! Thanks for all of your help! Quote
skipsophrenic Posted December 7, 2009 Posted December 7, 2009 might also be worth checking out CutePDF, i've never had any problems with it. Quote
dostuart Posted September 13, 2010 Posted September 13, 2010 I have a CAD drawing with wipeouts that I plotted to PDF via. CutePDF. The office I am in has two color printers. One prints the PDF with the wipeouts as black boxes while the other printer prints just fine. Quote
Spiderguy Posted September 14, 2010 Author Posted September 14, 2010 We are testing AutoCad 2011 (higher-ups decided to skip 2010) anyway, inside of it is a PDF converter, so far it is superior to Adobe Acrobat & bluebeam (which I think is lightyears beyond Adobe). It has some features that allow greater control of the information that goes with your files. So far the issue with the wipeout command has not raised it's ugly head! Thanks for all of your input! Quote
