PS_Port Posted June 28, 2009 Share Posted June 28, 2009 I've just had a look at the file you posted.. I get the same results as you , +-15'. DIMSTYLE will not fix your problem... there are no styles attached.. In fact whoever gave you that drawing went out of their way to make it non-user friendly. - Dimensions have been exploded - Hatches have been exploded - No layers - Everything has been purged, and put on Layer 0 - And the real kicker , the drawing has been scaled. Firstly I would scale the drawing back to 1:1, find a line of known length (real world), LIST it, use these different numbers to get a scale factor. Be carefule using stated dims, as these may be rounded or even overridden. Then create a dimstyle that matches the one you want, you might also have to create a textstyle to use in the dimstyle, as there are none on that drawing... Good luck. Quote Link to comment Share on other sites More sharing options...
