I've just had a look at the file you posted.. :) I get the same results as you , +-15'.
DIMSTYLE will not fix your problem... there are no styles attached..
In fact whoever gave you that drawing went out of their way to make it non-user friendly.
- Dimensions have been exploded
- Hatches have been exploded
- No layers
- Everything has been purged, and put on Layer 0
- And the real kicker , the drawing has been scaled.
Firstly I would scale the drawing back to 1:1, find a line of known length (real world), LIST it, use these different numbers to get a scale factor. Be carefule using stated dims, as these may be rounded or even overridden.
Then create a dimstyle that matches the one you want, you might also have to create a textstyle to use in the dimstyle, as there are none on that drawing...
Good luck. :)
  • Replies 20
  • CodeSnorter
    10
  • chelsea1307
    5
  • PS_Port
    3
  • stevsmith
    2
Posted Images
