Signs Posted June 26, 2009 Posted June 26, 2009 You know that little box that appears right beside your mouse on the drawing screen when you type in commands, numbers, etc. Also appears when you do the DIST command to see what distance is between two points. Well, I must have accidentally pressed something because it is gone now. How do I get it back? I don't even know what that feature is called. Quote
rkent Posted June 27, 2009 Posted June 27, 2009 You know that little box that appears right beside your mouse on the drawing screen when you type in commands, numbers, etc. Also appears when you do the DIST command to see what distance is between two points. Well, I must have accidentally pressed something because it is gone now. How do I get it back? I don't even know what that feature is called. Dynamic Input, look down at the bottom of the screen, pick the DYN button to toggle it on. Quote
