gsksun4 Posted June 29, 2009 Posted June 29, 2009 Are there hot keys for moving, rotating attributes in 2009LT like "AT" used to work in older versions? All I can do now is type in "-ATTEDIT". Quote
GE13579 Posted June 29, 2009 Posted June 29, 2009 Try ATE? You can learn some by just typing the first letter or letters and tabbing through all the options that could be started that way. I have no idea what is or isn't available in LT however... Quote
gsksun4 Posted June 29, 2009 Author Posted June 29, 2009 Try ATE? You can learn some by just typing the first letter or letters and tabbing through all the options that could be started that way. I have no idea what is or isn't available in LT however... Thanks, but "ATE" brings up the edit attributes window so you can edit the text, not move or rotate it. When I type in "AT" I get an attribute definition window with a rotation feature, but when I type in the new rotation number it says tag cannot be empty. I retype in the attribute, and now I have two attributes around the block and they've become regular text, not attributes. Also, I see no option to move attributes in this window. The tab thing is a good idea though. Quote
gsksun4 Posted June 29, 2009 Author Posted June 29, 2009 OK, I found out "ATTE" is the hot keys. Thanks. Quote
chelsea1307 Posted June 29, 2009 Posted June 29, 2009 havent used LT in forever but can you edit your pgp file to make it whatever you want? Quote
gsksun4 Posted June 29, 2009 Author Posted June 29, 2009 havent used LT in forever but can you edit your pgp file to make it whatever you want? You know, that's the first thing I tried, but couldn't find it. I looked in support where it's supposed to be, but no luck. Besides, I haven't done that since release 14, and I think you have to reload it and the .MNU file as well. Not sure. Quote
chelsea1307 Posted June 29, 2009 Posted June 29, 2009 in full version after you change it you type reinit and it reloads it. mine is in the support folder where its supposed to be Quote
gsksun4 Posted June 29, 2009 Author Posted June 29, 2009 in full version after you change it you type reinit and it reloads it. mine is in the support folder where its supposed to be I have 2002LT, 2006LT and 2009LT and can't find a .PGP file in any of them. Oh well, I can manage with the ATTE. Thank you for the effort. Quote
Cad64 Posted June 29, 2009 Posted June 29, 2009 Just go to your "Tools" menu, scroll down to "Customize" and then "Edit Program Parameters (acad.pgp)". At least that's where it's at in full Acad. Quote
gsksun4 Posted June 30, 2009 Author Posted June 30, 2009 Just go to your "Tools" menu, scroll down to "Customize" and then "Edit Program Parameters (acad.pgp)". At least that's where it's at in full Acad. Thank you. Finally found that nasty PGP file. Quote
