Please advise how I can transfer the toolbar settings from one machine to another both v14.
Many thanks
Here is a simple example:
If you need to use your customized toolbar on another machine, you need to export your customization and import it to another machine.
To save your current customization toolbar in a file, enter OPTIONS in command line, switch to PROFILE tab, and click EXPORT, give the output a name and save it as an ARG file.
Next time when you need this toolbar on another machine, just copy this ARG file and import it into your profile, set it current and use it.
Sean
AutoDWG
Sry, I did not notice it's in V14, the command is "preferences" instead of "options" in R14.
Sean
AutoDWG
Many thanks Seanfts
It works as you say.
As often on computers, you are only a few clicks away!
Regards
Westec
