Questions regarding insert frame command
hello,
i m working on structure using the 'insert frame' feature. and i notched the ends of the member by using notch command. now when i generate the part list, the length of that member is not updated as per the notch. is there any way to show the exact length of members in part list?
please help me?
also there are many members which are same. suppose there are 10 same members in the structure. so in part list the qty. should be 10. but by using the 'insert frame' command it creates 10 different parts. also in part list it shows 10 different items. is there any way that part list & ballon shows same item no. for all these parts?
