Going the VL route:
(defun c:test  ()
 (vl-load-com)
 (vlax-for blk  (vla-get-Blocks
                  (vla-get-ActiveDocument
                    (vlax-get-acad-object)))
   (vlax-for Obj blk
     (if (eq 3 (vla-get-color Obj))
       (vla-put-color Obj 1))))
 (princ))
  • Replies 25
  • SteveK
    12
  • Lee Mac
    11
  • The Buzzard
    3
Here's what I've done. I've made an edit form (at the bottom) so I can just put in different things in there and it will apply it to all objects:
; Start of command form: ***********************************
(defun c:cca (/ ss1 i en elst RGB_number)
 (setvar "cmdecho" 0)
 (command "UNDO" "BE") ; Begin UNDO group
 ; Search individual Entities=================================
 (setq ss1 (ssget "_X"))
 (setq i -1)
 (while (setq en (ssname ss1 (setq i (1+ i))))
   (edit en)
   ) ; End while
 ; Search and change all blocks==============================
 (foreach blk (getblk)
   (foreach sub (GetObj (tblobjname "BLOCK" blk))
     (edit sub)
     ) ; End Foreach sub
   ) ; End Foreach blk
 (command "REGEN")
 (command "UNDO" "E") ; End UNDO Group
 (setvar "cmdecho" 1)
; Returns List of entity names in block-------------------------------
(defun GetObj  (bObj)
 (if (setq bObj (entnext bObj))
   (cons bObj (GetObj bObj))))
; Returns list of block names------------------------------------------
(defun getblk (/ tdef lst)
 (reverse
   (while (setq tdef (tblnext "BLOCK" (not tdef)))
     (setq lst (cons (cdr (assoc 2 tdef)) lst)))))
; Makes changes to specified entity name (en)------------------------
(defun edit (en)
;Put in whatever changes you want to make to entities here
;Example:
 (setq elst (entget en)
   RGB_number (cdr (assoc 420 elst)))
 ; Remove RGB value
 (Setq elst
    (vl-remove-if
      (function
        (lambda (x)
          (eq 420 (car x)))) elst))
 ; Convert specific RGB values to specified ACI Colours
 (Cond ((= RGB_number 16737792) ; Orange
    (Setq elst (subst (cons 62 2) (assoc 62 elst) elst))) ; To Yellow
   ((= RGB_number 52479) ; Sky Blue
    (Setq elst (subst (cons 62 140) (assoc 62 elst) elst))) ; To Color 140
   ) ; End Cond
 (entmod elst)
 (entupd en)
Except now when I try to implement the VL code in place of:
; Search and change all blocks================================
     (edit sub)
     ) ; End Foreach sub
   ) ; End Foreach blk
IE something like:
(vl-load-com)
   (vlax-for Obj blk
     (edit Obj)
Obj is not an entity name so this doesn't work. Can you correct this? (nothing too incomprehensible please :))
Hey Steve, my posted code will change the colour using a VL method - as each item I am working on is now a VLA-Object.
You could either go the VL route and edit the objects using VL methods, or stick to plain AutoLISP and convert the VLA-object back to an ename using:
(vlax-vla-object->ename Obj)
Hope I'm not overcomplicating things here :oops:
I'll look at your code and see if I can explain things better for you :)
Lee
I've tried not to change your original code too much, but just add my snippet:
 (setq i -1)
   (edit en)
   ) ; End while
(vl-load-com)
   (vlax-for Obj blk
     (edit (vlax-vla-object->ename Obj))
 (command "REGEN")
(defun edit (en)
;Example:
 ; Remove RGB value
 (Setq elst
    (vl-remove-if
      (function
        (lambda (x)
   ) ; End Cond
 (entmod elst)
 (entupd en)
Yeah great, vlisp does the trick. For the big drawing it took about 2minutes but it worked :) So the lesson learnt is there is no simple autolisp method -> learn vlisp :)
Thanks Lee
Thanks Lee
I find VLisp easier, now that I have gotten to grips with it. Although I would recommend that you are competent with standard AutoLisp first. Visual LISP can be a bit daunting at first, as there are a few more data types to deal with, - like safe-array's and variants, but once you get the hang of it, you should be ok :)
