Anyone can figure out my problem.. Why the attached material is no effect in the other railings.. What should i do?
after you union the solids try to apply the material again:)
Sir, no effect at all.! my goodness.
Try placing the railings on a layer,(lets say A-RAILINGS), then use MATERIALATTACH to place the material on the layer of the railing instead of attaching it from RMAT. if it dont work, check it first on a rendered window. if still it dont work... well lets do the propsed sugestion first..
