SteveB
Locked Viewport
SteveB
I've been e-mailed a plan which I have subsequently amended however when I come to scale It says "viewport is viewlocked switching back to model space" I can't unlock it to move and scale it in the usual way:cry: I'm using Autocad 2000.
I would really appreciate any help as I've been trying allsorts for 3 days!! Thanks.
Share this post
Link to post
ReMark
So you have selected the viewport and then right-clicked and tried (unsuccessfully) to disable the display locked option?
Share this post
Link to post
SteveB
Yes exactly thats the frustrating thing ReMark
Share this post
Link to post
GE13579
Can you post the drawing at all?
Share this post
Link to post
ReMark
The only other place I know of that you can turn off view-locking is in the Properties window. But from what you are saying I expect that to indicate that the view is locked and I doubt you'll be able to change the setting.
Share this post
Link to post
SteveB
Not sure what do you mean by post?
Share this post
Link to post
GE13579
Attach it onto the site- scroll down to Manage Attachments...
Share this post
Link to post
Glen Smith
Could there be a second, larger, viewport that you aren't seeing? If I get impatient when I create a new drawing using a template with the viewport already in the titleblock and try to start work before it is done, AutoCAD occasionally creates a viewport 5-10 times larger than the paperspace I am using. If I don't realize it, things can get rather confusing.
I doubt this will be any different, but try using a macro:
^C^C_-VPORTS;_LOCK;OFF
Glen
Share this post
Link to post
rkent
At the command line, Mview, Lock, Off, All
Share this post
Link to post
SteveB
Thanks just trying that now Glen
Share this post
Link to post
ammobake
I think you can also select the viewport, right click, and turn off the lock that way. But the viewport has to be showing so you can select it first.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
