Can't find a flyout for snap settings I can use while in a command. I don't usually set all the osnaps I use in dsettings because they sometimes get tangled while in a command.
There must be one I can add to one of my toolbars. I looked under the users guide and didn't understand the info. I also went into tool palettes, but that didn't help.
There isn't one in the object snap toolbar.
does shift-right click give you what you want?
Yes it does and I thank you, but I prefer the flyout. I'm just used to using one, that's all.
ok. I never use them so I can't answer
It's OK, if I can't work out the flyout, I can use your suggestion. It's a great and easy tip.
Thanks again, I'm a slow learner.
