Removing unseen entities in Complex 3-d drawings?
I need to remove entities in turned off layers so I toggle my "ON layers" to off and
my "OFF layers" to on and erase the hidden entities then I toggle the layers back
to the orginal state. I would think that would only erase entities in unseen layers.
That is not the case. I end up erasing something in an orginal layer that is on
in the first place.
Is there an easy another to erase unseen entites & remove their layers and
ensure that the shown entities remain in my drawing?
Note I am dealing with complex 3-d drawings that have 100 plus layers with
about 10 layers turned off. Typical.
I am doing this to convert all layers to a single layer called Level 1 for microstation
conversions. With all the 3-blocks etc, this is becoming a challange.
Can anyone help?
Thank you,
What AutoCAD version are you using?
Layer Delete command. Look under Format > Layer Tools.
I am using version 2009.
What I need is something that would purge unseen entities.
What is the difference between freeze and turning a layer off. That might
help.
"Is there an easy another to erase unseen entites & remove their layers..."
Maybe I wasn't clear. Layer Delete.
This command will erase a layer and all entities on that layer whether it is on, off or frozen. The command doesn't care. That's why one must be careful when using it.
Re: Layer off vs. frozen.
May I recommend AutoCAD Help? See Layers > turning on or off. Then on the Concept tab read the section entitled Control the visibility of objects on a layer. It clearly explains the difference between the two.
