halu again..I have a ready 3d house in Auutocad file. Is it possible to export an Autocad file into 3ds max 6? if it is what are the steps? thanks a lot.
You can Import the .dwg directly into Max. Go to the "File" menu and select Import. Then select "Autocad Drawing" from the "Files of Type" list.
You can also use the File Link Manager. This will allow you to basically xref your dwg file into Max so that any changes to the CAD file can be updated into the Max scene.
I don't know if these options are available in Max 6 though. You will just have to check and see.
