vivekgrs Posted April 21, 2008 Posted April 21, 2008 hi friends, i want 2 write the lisp porgram for export the dwg into shape file. can anyone help me regard this. regards vivek Quote
rkmcswain Posted April 21, 2008 Posted April 21, 2008 Just drive the "MAPEXPORT" command. Example: [color=blue][font="Courier New"] (command "._mapexport" "SHP" "C:\\temp\\test.shp" "_N" "_S" "_LINE" "_ALL" "*" "*" "_N" "_Proceed") [/font][/color] Your responses may vary.... Quote
M76 Posted August 11, 2011 Posted August 11, 2011 Could you please elaborate on which parameter does what? I could find no reference on this, and I'd like to export polygons from topologies. Quote
BlackBox Posted August 11, 2011 Posted August 11, 2011 Sometimes, the best way to understand what is happening is to manually enter the command (mapexport in this case), and follow the command prompts. The code above does the exact same as you would (potentially) yourself. Quote
lmorse Posted January 21, 2021 Posted January 21, 2021 Would anyone have experience in exporting an attribute table via command line? Using the dialogue box, this is on the Data tab, so I am assuming something like this...? (command "._mapexport" "SHP" "C:\\temp\\test.shp" "_N" "_S" "_LINE" "_ALL" "*" "*" "_N" "_D" "MyTableName" "_Proceed") Quote
