bartarch Posted July 13, 2009 Posted July 13, 2009 Hi.I have problem with gradient fill and solid fill on my print and .pdf. For example: I fill the shape solid color or gradient and I plot it on my printer or plot to .pdf. All the fills looks like by partly moved out of the shape.The shape and fill don't match together. The fill is visible only in the shape and disapear out of the shape. Any ideas what happen? How to resolve this problem? Thanks for help Quote
Tankman Posted July 13, 2009 Posted July 13, 2009 Is this an "on screen" viewing problem or a print problem? I sometimes experience your viewing difficulty however the printed copy appears fine. You might try "regen" to see if your drawing and view appear clean. Quote
bartarch Posted July 13, 2009 Author Posted July 13, 2009 On screen is OK. Problem is only with print or .pdf. Quote
Tankman Posted July 13, 2009 Posted July 13, 2009 On screen is OK. Problem is only with print or .pdf. What resolution is your printer set at? You might trying to print to a higher resolution. Quote
bartarch Posted July 13, 2009 Author Posted July 13, 2009 What resolution is your printer set at?You might trying to print to a higher resolution. The resolution is 720 dpi.But when is 360 dpi problem i s the same. Quote
bartarch Posted July 13, 2009 Author Posted July 13, 2009 The gradient fill all the rectangular on screen in AC, but in .pdf or print looks like that. http://img140.imageshack.us/i/gradient.pdf/ Quote
