I've just recently become acquainted with the DVIEW command as well as the Orbit right-click method in order to switch between perspective/parallel views of 3D objects. I was wondering if you could bring the vanishing point closer to the object so the skew would be more noticeable due to the small size of the section I've drawn.
Thanks in advance, these forums look like a huge source of info and I look forward to any help I can give and take.
not sure, just try to change your camera's lens,:D
