spittle Posted July 14, 2009 Posted July 14, 2009 As per title, any ideas if it would be possible to make for example a window automatically cut hole in a wall in separate part when it's inserted into an assembly? So you could add you mate references to your window part and drag it on to your wall and cut out the extra work. Also you could then have different configurations that will change the size of the hole. I know I could link a sketch in the wall part to the window but I want to cut that bit out if possible. Thought someone might have an idea of some kind of fudge that would do this. Quote
