MikeP Posted July 17, 2009 Share Posted July 17, 2009 When I render my drawing it tells me there are assets missing and list a few of the materials that i have used. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted July 17, 2009 Share Posted July 17, 2009 Have you moved the file from its original location? Are these custom bitmap materials or standard Autocad materials? Have you checked to make sure the materials still exist in the correct location on your computer? Quote Link to comment Share on other sites More sharing options...
MikeP Posted July 17, 2009 Author Share Posted July 17, 2009 Have you moved the file from its original location?Are these custom bitmap materials or standard Autocad materials? Have you checked to make sure the materials still exist in the correct location on your computer? I have not moved anything. these are the from the tool palets. where should I go looking for them? Quote Link to comment Share on other sites More sharing options...
Cad64 Posted July 17, 2009 Share Posted July 17, 2009 Open your "Options" dialog, "Files" tab and click on "Texture Maps Search Path". This will tell you where your materials are stored. Quote Link to comment Share on other sites More sharing options...
MikeP Posted July 17, 2009 Author Share Posted July 17, 2009 Open your "Options" dialog, "Files" tab and click on "Texture Maps Search Path". This will tell you where your materials are stored. Ok so Im missing the entire "texture" folder. Now what? Quote Link to comment Share on other sites More sharing options...
miroslav_s Posted October 22, 2012 Share Posted October 22, 2012 Hi, I am having the same problem when I press "render" button I get this message: Missing assets Graymarb.tga Palmfrnd.tga I did that "chech" as described above but I don´t understand what to do after that. Best regards Miro Quote Link to comment Share on other sites More sharing options...
