Is there any method by which my valves & Process Lines in P&ID can be numbered automatically using AutoLISP?
I am not sure if this is what you are looking for, But check these links, Many choices:
http://www.cadtutor.net/forum/showthread.php?t=37420
http://www.cadtutor.net/forum/showthread.php?t=35234
http://www.cadtutor.net/forum/showthread.php?t=14938&highlight=automatic+numbering
http://www.cadtutor.net/forum/showthread.php?t=11114&highlight=P%26amp%3BID+NUMBERING
http://www.cadtutor.net/forum/showthread.php?t=20103
I'm not quote sure.This is what I am looking for. Let's say I am generator a P&ID. Everytime I add a ball valve are a check valve it will automatically number that valve. When I add another of the same type it will give it another consecutive number or something along those lines.
Now all vallves come in class ratings, 150#, 300#, 400#, 600# on up. A 150# flanged ball valve id is called as by size, then (A2R). The A = 150#, 2 = ball valve, R = Flanged.
So a 6" 150# ball valve's id is 6"-A2R OR 6"A2R. This is already part of the valves which I do not want edited.
Sounds like a custom program with blocks and attributes. Maybe someone will tackle it. I guess you will have to wait it out and see.
How about posting a sample DWG wit a few of your valves.
A Before & After would be nice.
Saves a lot of guess work!
  • 3 years later...
Where do I find the Legend showing these values?
1= ?
2= ball valve
3= ?
A=150#
B=?
C=?
Thanx Mac
If not an industry, or application configurable standard, this is usually a naming convention explained in one's plan set legend.
I've not used P&ID for production, but from what little I understand of it, it works well with other utility, and process piping based verticals such as Plant 3D, AMEP, etc., so given the vertical nature, methinks this is another Style-based label (without seeing a sample drawing).
I have to decode a P&ID with these on it and without the aid of a front sheet or legend.
Was hoping "laison" might have it as it seems he has worked on the same drawings or used this same system convention.
usglfvet,
it's hard to help without realizing exactly what you need, as CAB wrote, post a sample dwg, with a before & after, without it, we can only guess.
Henrique
