tamohr Posted July 22, 2009 Share Posted July 22, 2009 Hello, I need a LISP routine that will allow me to draw a line with a “Z” coordinate. I would like to click on a spot in current x,y plain and then be prompted to enter a “Z” or ELEVATION for the start of the line and then click on the end of the line and be prompted again to enter the “Z” coordinate. The end of this line will be the beginning of the next line and then continue picking and entering “Z” coordinates to form a series of 3D lines each having the same “Z” coordinate at their intersections. Any help would be greatly appreciated, thank you! Quote Link to comment Share on other sites More sharing options...
DHUDELSON Posted July 24, 2009 Share Posted July 24, 2009 Rather than LISPing, you could just use your .xy filter. After hitting the Line command, type ".xy" enter, pick x & y location...you'll then be prompted for z, type & enter your elevation and your line will be up where you want it. If you already have an entity in your dwg at your desired z, you can pick on it with a "near" snap rather than typing the value in your command line. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 24, 2009 Share Posted July 24, 2009 Hmmm... now where have I seen this before... http://www.cadtutor.net/forum/showthread.php?t=38504 PLEASE DON'T DOUBLE POST. Thanks Quote Link to comment Share on other sites More sharing options...
