hello everyone
do inserted raster images loose some quality when inserted in CAD?
would i be better off inserted the images onto PDFs is photoshop?
i dont think they do lose quality, i guess it depends on the raster image itself. try plotting the raster image from autocad and see the results.
everytime i do it though it doesnt lose quality.
thanks! the images are pretty large files, any way to not have them slow down autocad?
also, how do i get the box from around the image
not sure you can do that with images in autocad, though you could make the image smaller.
type IMAGEFRAME into the command line and set the variable to 0. that should get rid of the border.
cant think of a way to get the box around the image away but if its viewports you are using then you could make the viewport just inside the border.
thanks, i am actually inmporting them into paperspace, but the viewport idea is a good one i will try that
sorry i edited the reply as i manged to remember the command hehe
that worked great!! thanks
No problem Rudbeckia :wink:
