Cap2 Posted July 22, 2009 Posted July 22, 2009 Can I load or insert a scanned image into layer to sketch from or set points on from a second layer. Quote
skipsophrenic Posted July 22, 2009 Posted July 22, 2009 Just so i understand you want to scan an image in and then trace over it? Quote
chelsea1307 Posted July 22, 2009 Posted July 22, 2009 you can insert an image and scale it to the appropriate size then draw over it, you cant snap to point on the image so its not super accurate Quote
Tankman Posted July 22, 2009 Posted July 22, 2009 you can insert an image and scale it to the appropriate size then draw over it, you cant snap to point on the image so its not super accurate You can place the image behind your known dimensions. Doing so, gives you a dimensioned image, not bad for the simple "junque" that I do. All 2D plan and elevation views. Quote
Cad64 Posted July 23, 2009 Posted July 23, 2009 To insert an image into your drawing, use the IMAGEATTACH command. Or go to your "Insert" menu and select "Raster Image Reference". Quote
Cap2 Posted July 23, 2009 Author Posted July 23, 2009 Just so i understand you want to scan an image in and then trace over it? That is correct. I would like to place the image on level 1, then complete the trace on level two. Quote
Cap2 Posted July 23, 2009 Author Posted July 23, 2009 To insert an image into your drawing, use the IMAGEATTACH command. Or go to your "Insert" menu and select "Raster Image Reference". I tried the Raster Image function with a jpeg format file and couldn't see that it loaded the file, the autocad page remained blank. Any suggestions. Quote
Cap2 Posted July 23, 2009 Author Posted July 23, 2009 Ok Doing so, gives you a dimensioned image, not bad for the simple "junque" that I do. All 2D plan and elevation views. It soulds like your working in the same area of my interest. Can you expand a bit on this Quote
Ritch7 Posted July 23, 2009 Posted July 23, 2009 I tried the Raster Image function with a jpeg format file and couldn't see that it loaded the file, the autocad page remained blank. Any suggestions. it's there, do a zoom extents or it might be there but very small scale, depends what sizes and scales you're working with Quote
