laison Posted July 23, 2009 Posted July 23, 2009 I have a partial menu that I finally got to load. The thing is, the pulldown and toolbar did not appear after I closed the CUI interface. The menu is below. // // AutoCAD menu file - C:\AutoCAD Library\Menus\civil.mnu // ***MENUGROUP=CIVIL ***POP1 **CIVIL ID_Civil [Civil] [--] [->3D Functions] ID_3DSTEEL [3DSTEEL]^C^C3DSTEEL ID_3DCAGE [3DCage]^C^C3DCAGE [3D Cylindrical Stairs]^C^C3DSTAIR ID_3DGrating [3DGrating]^C^C3DGRATE [ [--] [->3D Editing] ID_009 [Modify Grating]^C^C3DGRATE_MOD ID_3DCope [3DCope]3DCope^C^C3DCOPE ID_3DCut [3DCut]^C^C3DCUT ID_3DSlice [3DSlice]^C^C3DSLICE ID_3DJoin [3DJoin]^C^C3DJOIN ID_3DLengthen [3DLengthen]^C^C3DLENGTH ID_3DModify [3DModify]^C^C3DMODIFY ID_3DSquare [3DSquare]^C^C3DSQUARE ID_3DMiter [3DMiter]^C^C3DMITER ID_3DMirror [3DMirror]^C^C3DMIRROR ID_3DOffset [3DOffset]^C^C3DOFFSET ID_3DRotate [3DRotate]^C^C3DROTATE ID_3DUpdate [ ID_013 [--] ***TOOLBARS **CIVIL ID_CIVIL [_Toolbar("Civil", _Floating, _Show, 50, 150, 1)] // // End of AutoCAD menu file - C:\AutoCAD Library\Menus\civil.mnu // Quote
lpseifert Posted July 23, 2009 Posted July 23, 2009 Assuming you loaded it and it created a .cui file named Civil.cui... You'll need to add the menu to your workspace. Open the CUI. In the left pane select the workspace you want the menu added to. In the right pane select Customize Workspace. Expand Menus (you should see all the menu pulldowns in the workspace). In the left pane expand Partial CUI Files, Civil, Menus. From the Menu tree, drag and drop the Civil menu to the position you want in the right pane. Similar for the Toolbar, i'm guessing. Or rt-clk in the grey area where a toolbar is (not on a toolbar), you should be able to select the Civil tolbar for display. Done Quote
laison Posted July 24, 2009 Author Posted July 24, 2009 ok, I did that and the toolbar showwd up but not the pulldown. Quote
