Beano Posted July 24, 2009 Posted July 24, 2009 I have a simple dynamic block with a move action assigned to it. I have used it a bit in the past. I use insert it in paperspace due to scaling and push it through to model space. Normally works fine but today on several drawings when I send it to model space it loses its move action. Quote
feargt Posted July 24, 2009 Posted July 24, 2009 Check that the X, y, and Z scale factor are all the same. If they are all the same, enter the scale factor again for each. It can be that the Z factor varies by a tiny amount which does not show up on the properties palette (ie. 0.0000000001) Quote
Beano Posted July 26, 2009 Author Posted July 26, 2009 Thankyou very much. They did all view the same but once re entered the action returned. Again Thanks. Quote
