Helge Posted July 24, 2009 Posted July 24, 2009 When I turn layers on or off, the screen stays the same until I perform a Quick Save. A View>Regen isn't enough. Even though it is prudent to save ones drawing regularly, this is a little too much and quite annoying. (System: AutoCad Mechanical 2008, Intel Core 2 Duo, 3 GHz. - 2 MB RAM, Windows XP 2002,SP3 - nVidia Quadro FX 570, Driver: 6.14.0011.7805, - Application driver: wopeng 19.hdi.) Anny help, please ... Quote
StevenMc Posted July 24, 2009 Posted July 24, 2009 When I turn layers on or off, the screen stays the same until I perform a Quick Save. A View>Regen isn't enough.Even though it is prudent to save ones drawing regularly, this is a little too much and quite annoying. (System: AutoCad Mechanical 2008, Intel Core 2 Duo, 3 GHz. - 2 MB RAM, Windows XP 2002,SP3 - nVidia Quadro FX 570, Driver: 6.14.0011.7805, - Application driver: wopeng 19.hdi.) Anny help, please ... does this happen all the time or is it just with the one drawing? Quote
Zorg Posted July 24, 2009 Posted July 24, 2009 That is strange, i would do a regenall (REA) and try an audit on your file, if its been passed around and other people have worked on it, it cna oftenly pick up errors which an audit will 9/10 fix. Quote
Helge Posted July 25, 2009 Author Posted July 25, 2009 Dear friends. Thanks for your interest. The problem occours "only" when the drawing gets past the initial stage, but still consist of just single components wihtout x-refs or big assemblies. File size of 1.800 KB, and it starts even much earlier. RegenAll does as little good as Regen, and the file has never been out of my PC. I wouldn't think that the grafic RAM of 256MB should be insufficient Quote
StevenMc Posted July 28, 2009 Posted July 28, 2009 a little more RAM could do the trick, it would also be recommended for easier and faster drawing Quote
