hi
i added a new line layer...
centrex2 .
when i draw with it , the linetype is not shown and its just a continous line? how can i get the detail of the line to show?
the line itself is at max 60mm in length
Try scaling the line down a bit
KC
hi
how do i scale down a line?
Try Zooming in on a portion of the line. I'm guessing the linetype is correct, it's just too small to be seen from a distance. You can play with your LTSCALE to adjust the linetype scaling.
Also, each time you change LTSCALE values, be sure to do REGEN to see the result.
