I've found a way to rename xrefs with this script and it works fine. It basically changes the old xref to a new xref.
-rename
b
TBA0_old
TBA0_new
-xref
p
TBA0_new
"C:\NEW XREF\TBA0_new.dwg"
The problem is I have a lot of different xrefs thats changed and a lot of dwgs to repath. The floor plan of a 20 story building changed it's format. Level 0 changed from xxxFP00 to xxxFPP1, xxxFP01 to xxxFP00, xxxFP02 to xxxFP01... So basically everything is shifted one level, and I have a whole bunch of dwgs with different xrefs to fix. I could write a script to fix each level I guess, but it should be simple to make it into a lisp file, but I don't know how to go about this. Please help.
  • Replies 43
  • JeepMaster
    12
  • ronjonp
    10
  • Lee Mac
    6
  • RyanGC
    5
Posted Images
Nice one Ron.
I believe your code could be incorporated into a bit of ObjectDBX to use on a whole folder of drawings :thumbsup:
Lee
Here's a quickie that should do what you need. just add to the list of block names ("existname" . "newname")
(defun c:blkrenamer (/ b bcol)
 (setq bcol (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))))
 (foreach blk '(("xxxFP00" . "xxxFPP1") ("xxxFP01" . "xxxFP00") ("xxxFP02" . "xxxFP01"))
   (if    (not (vl-catch-all-error-p
          (setq b (vl-catch-all-apply 'vla-item (list bcol (car blk))))
     (vla-put-name b (cdr blk))
Thanks Ron, this one works great, but I still can't get the repath lisp to work. I don't think it will do as it changes the xref path. For my purpose, my xref path is actually unchanged, but the actual xref drawing is.
Anyways, I've managed to modify your rename lisp and made it work for my purpose. But I need to make it as user friendly as possible so I can share it with my all my co-workers. How can I make the -xref command loop like the (foreach...) function? And some kind of error trap to move on to the next xref if this xref doesn't exist. Here's what I have so far.
(defun c:Xrefchanger (/ b bcol)
 (foreach blk '(
;*******  Enter xref names below in this format  ******
;*******  ("OldXrefName" . "NewXrefName")        ******
("oldxref1" . "newxref1")
("oldxref2" . "newxref2")
   (if(not (vl-catch-all-error-p
;*****  Enter new xerf name and full path below in this format *********
;****  "NewXrefName" "c:\\new path\\NewXrefName.dwg"           *********
(command "-xref" "p" "newxref1" "c:\\new xref\\newxref1.dwg")
Try this one to rename and change the name of the dwg in the path. I did not test it heavily...
It seems from doing this in the past that the results can only be viewed immediately using CLASSICXREF...when you reopen the drawing the changes should take effect.
(defun c:blkrenamer (/ b bcol path)
   (if
     (and
      (not (vl-catch-all-error-p (setq b (vl-catch-all-apply 'vla-item (list bcol (car blk))))))
      (= (vla-get-isxref b) :vlax-true)
      (progn (vla-put-name b (cdr blk))
         (if (= (setq path (vl-filename-directory (vla-get-path b))) "")
       (vla-put-path b (strcat (cdr blk) ".dwg"))
       (vla-put-path b (strcat path "\\" (cdr blk) ".dwg"))
I'm getting:
bad argument type: VLA-OBJECT nil
Should be:
   (if
     (and (= (vla-get-isxref [b][color=Red]blk[/color][/b]) :vlax-true)
Me thinks :)
I'm getting:
My bad. :oops: Give it a whirl now :)
Should be:
   (if
Me thinks :)
      (and
:P
      (and
:P
Ahh, of course :oops: :oops: :oops:
Thanks Ron,
It works now. I've added my other XRE.lsp on there so it will refresh all loaded xrefs right after it.:D
This is what I have now.
 (foreach blk '(("xxxFP01" . "xxxFP00") ("xxxFP02" . "xxxFP01")
   (if
     (and
 (c:XRE)
(defun c:xre (/ cObj cName)
 (defun *error*(msg)
   (setvar "modemacro" ".")
   (setvar "cmdecho" 1)
   (princ "\n...Reload xref terminated!!!  ")
   ); end of *error*
 (setvar "modemacro" "Reloading loaded xrefs......please wait......")
 (setvar "cmdecho" 0)
 (setq cObj(tblnext "BLOCK" T))
 (while cObj
   (setq cName(cdr(assoc 2 cObj)))
   (if
     (and
    (=(logand(cdr(assoc 70 cObj))32)32)
    (=(logand(cdr(assoc 70 cObj))4)4)
    ); end and
      (vl-cmdf "_.xref" "_unload" cName)
      (vl-cmdf "_.xref" "_reload" cName)
      ); end progn
     ); wnd if
 (setq cObj(tblnext "BLOCK"))
 ); end while
 (prompt "\n--- Refreshed loaded Xrefs! ---")
 ); end of c:xre
Thanks Ron,
   (if
     (and
 (c:XRE)
 (defun *error*(msg)
   ); end of *error*
 (while cObj
   (if
     (and
    ); end and
      ); end progn
     ); wnd if
 ); end while
 ); end of c:xre
You could add (vla-reload b) like so and it should reload without the need for the other lisp :D. Glad we got it sorted out....I'm gone fishing for the next 5 days so Lee will have to pick up from here :P
   (if
     (and (= (vla-get-isxref b) :vlax-true)
         (vla-reload b)
...I'm gone fishing for the next 5 days so Lee will have to pick up from here...
I'd be happy to :)
Thanks so much Ron,
It works perfectly now. I know this will save a lot of people's time when some smarta$$ decides to change their floor plan name in the middle of the project. A few dwg is fine, but when you have over 80 dwgs to fix, then times that by 3 since it affects Mech, Elect, Struct....that's a lot of time wasted.:D
I'd be happy to :)
Thanks Lee,
It seems to work great now. Unless you want to improve it some more.:D
I'm glad it works for you... I doubt I could improve on a code posted by Ron... :P
Try this:
Start --> Programs --> Autodesk --> AutoCAD 20xx --> Reference Manager
I designed an application to cater for these needs and then discovered this Autodesk freebie so abandoned my plans.
Hope this helps.
