ronjonp Posted July 21, 2016 Posted July 21, 2016 Just a shot in the dark but try taking out the line (vla-reload b). Quote
Tripledot Posted July 22, 2016 Posted July 22, 2016 Just a shot in the dark but try taking out the line (vla-reload b). Hi ronjonp. It somewhat worked. I ran the routine & the command line indicated Command: xrefr Initializing... U:\.........\.......\.........\.......\xxxx.DWG U:\.........\.......\.........\.......\yyyy.DWG --- Xref change finished! --- But no change in the drawing & in Externally Reference box, nothing changed. But i still save the dwg & open again & the xref path now show the new path. How to get it to reflect the changes when the lisp runs instead of having to save & reopen the drawing to reflect the changes. Thanks Quote
ronjonp Posted July 22, 2016 Posted July 22, 2016 Not the best solution, but you could call (command "-xref" "reload" "*") at the end of the routine. Quote
Tripledot Posted July 23, 2016 Posted July 23, 2016 Not the best solution, but you could call (command "-xref" "reload" "*") at the end of the routine. Do you know why it happend? where do i add this line of code to? Thank ronjonp Quote
