Delta-Sword Posted July 29, 2009 Posted July 29, 2009 I need to issue a drawing for a lighting layout with different hatch for the lux level. i have hatched the areas with dots however i need 3 different hatch scales. 2 which have been accepted however i cannot get a 3rd scale which is suitable. what i am looking for is a way to make a hatch which is basically transparent so you can still see the other drawing underneath without using plot styles. Many thanks for your help Quote
StevenMc Posted July 29, 2009 Posted July 29, 2009 Hi D have you tried this type PLOT. then go to -PROPERTIES -GRAPHICS -MERGE CONTROL -LINES MERGE. that could do the trick Quote
StevenMc Posted July 29, 2009 Posted July 29, 2009 http://www.cadtutor.net/forum/showthread.php?t=36482&highlight=Transparent i had this problem previously. Quote
