Manual/automatic Changelog.txt!
Hello how is everyone here?
its been a while for me sinds I posted here so it was about time to ask something/ ;-)
I would like to keep a simple change log for my drawings.
and I was thinking to do it in a .txt file for each drawing.
a small description of the editing made after I'm done with it.
not a huge problem to do it manualy...
But is it possible to make the .txt file pop up when I hit save after I close a drawing.
Lets say I'm working on xyz.dwg and I'm done with it for today and close save. auto cad automatically opens/creates xyz.txt in the same folder so I can type in what I changed in a short description with the date etc...
I know auto cad keeps log files of your commands so I was wondering maybe it can do this to. perhaps with a lisp or so?
hope I explained good!
I think this would get a better response in the LISP forum.
But yes, I believe this can be done with a reactor based LISP.
Thx,
Good to hear that it could be possible to do this.
Not good because I don't know how to work with LISP.
Is there any way someone could help me out?
I don't have any idea if its easy or hard to write a lisp for this.
can anyone move this thread to the LISP forum?
Thx, for moving this thread.
I looked into LISP and I think I'm not cut out for this kind of stuff :cry:.
Maybe if someone could push me into the right direction?
Should the first step be to make autocad:
1- open the .txt together with the drawing or to create the .txt file if it doesn't exist yet. this way I can update the log file while I draw.
2- make/create a .txt file after I hit close.
I think the first one is going to be the easiest to write and to work with.
and if possible could the lisp automatically add a dashed line and 2 or 3 empty paragraphs on each side when the .txt file opens? (the last edit should be in the beginning of the file.)(and maybe the date and editing time)
I feel like I'm asking to much here???:lol:
Hey Attila,
Try this for starters:
(defun c:LogON ()
 (vl-load-com)
 (if (setq *log#
       (getfiled "Select Log File"
         (if *log# *log# "") "txt" 9))
   (if (not *r#log)
       (setq *r#log
         (vlr-command-reactor nil
           (list
             (cons :vlr-CommandWillStart 'logCom))))
       (princ "\n<<- Reactor Initiated ->>")))
   (princ "\n*Cancel*"))
 (princ))
(defun logCom (Call rArg / file)
 (cond ((not (wcmatch (car rArg) "*SAVE*"))
        (setq file (open *log# "a"))
        (write-line (car rArg) file)
        (close file))
       (t (startapp "notepad" *log#)))
 (princ))
(defun c:LogOFF ()
 (if *r#log
     (vlr-remove *r#log)
     (setq *r#log nil)
     (princ "\n<<- Reactor Deactivated ->>")))
 (princ))
Instructions for running:
  • type LogON to start the reactor, and select a txt file, or create a new one.
  • Try some commands, draw stuff.
  • hit save.
  • Type LogOFF to deactivate the reactor.
Lee
Thats a nice start indeed! the .txt pops up.
Its not necessary for me to save the commands.
something like this is enough for me!
[i](manually write a small description after date time and separation line automatically inserted)[/i]
Made changes to parts 1-3-4-12: due to client request!
holes where 6mm diameter now they are 8mm.
30/07/09[i] (automatically add date)[/i]
00.15 [i](automatically add edit time)[/i]
-------------------------------------------[i] (automatically add line)[/i]
Made part 14 thicker by 1mm to provide better stability.
29/07/09
00.10
Older description of editing
older date
older edit time
it also overwrites the previous log! when I start te lisp for the second time.
How about:
(defun c:LogON ()
 (vl-load-com)
 (if (setq *log#
         (if *log# *log# "") "txt" 41))
   (if (not *r#log)
       (setq *r#log
           (list
 (princ))
 (cond ((wcmatch (car rArg) "*SAVE*")
        (write-line (pad "" 45 45) file)
        (close file)
 (princ))
(defun c:LogOFF ()
 (if *r#log
     (vlr-remove *r#log)
     (setq *r#log nil)
 (princ))
(defun Pad (Str Chc Len)
 (while (< (strlen Str) Len)
   (setq Str (strcat Str (chr Chc))))
 Str)
You needn't start the lisp each time, it is a reactor, just one run per session.
And it should overwrite the file - it opens it to append.
Where getting closer Lee!
it works fine with just one small problem or 3 :)
Is it possible to add:
1 empty line on both side separation.
and
I would like to keep the last edit in the begin of the file so when I have 100 log days, day 1 would be way down in the file and day 100 in the first log in the file.
thx so far LEE (I find you very genially!:D)
Ok.
I have added the extra lines between the revisions.
Now, as the for reversing.
Write-line cannot write the lines backwards, so I have had to read the whole file, add the extras, and re-write the file.
This means that when you start for the first time, the file must have something in it to start with.
Lee
(defun c:LogON ()
 (vl-load-com)
 (if (setq *log#
   (if (not *r#log)
       (setq *r#log
           (list
 (princ))
(defun logCom (Call rArg / file nl lst)
 (setq lst '())
        (setq file (open *log# "r"))
        (while (setq nl (read-line file))
          (setq lst (cons nl lst)))
        (close file)
        (setq lst
          (append
            (list "" "" (pad "" 45 45) "")
              (reverse lst)))
        (setq file (open *log# "w"))
        (mapcar
          (function
            (lambda (x)
              (write-line x file))) lst)
        (close file)
 (princ))
(defun c:LogOFF ()
 (if *r#log
     (vlr-remove *r#log)
     (setq *r#log nil)
 (princ))
 Str)
Ill give this a try at home!
your help is much apriciated Lee!
I'm going on vacation for 3 weeks! so its possible you won't here from me for awile!
thx again and see you tomorrow or in 3weeks!
Enjoy your vacation mate, hope this works out for you :)
Lee
