flyingrizzly Posted July 29, 2009 Posted July 29, 2009 I just finished a drawing and now I would like to create a separate window on the same drawing to focus in on a specific item. I cannot find the command in the book or on the help menu. I am pretty sure the circle needs to be a "poly" but besides that I'm stumped:? Quote
StevenMc Posted July 29, 2009 Posted July 29, 2009 or you could go to TOOLS-TOOLBARS-AUTOCAD-VIEWPORTS, then you would have the command on your toolbar Quote
flyingrizzly Posted July 29, 2009 Author Posted July 29, 2009 is it a circle viewport you are after? Yes it is. I want to draw a small circle around the object and then draw two lines to a larger circle with the object zoomed in. Quote
Cad64 Posted July 29, 2009 Posted July 29, 2009 Any closed shape can become a viewport. Draw out a circle, then type MVIEW and choose the "Object" option. Then just select the circle and it will become a viewport. Or you can use the "Convert Object to Viewport" button on the Viewports toolbar. Quote
flyingrizzly Posted July 29, 2009 Author Posted July 29, 2009 this may help... Thanks for the .dwg but I want to be able to do it myself for later without having to carry around your drawing. I have the viewport toolbar but still am not sure how to work it Quote
StevenMc Posted July 29, 2009 Posted July 29, 2009 Thanks for the .dwg but I want to be able to do it myself for later without having to carry around your drawing. I have the viewport toolbar but still am not sure how to work it see CAD64's comment on how to do it. thats how the viewports in the dwg were made Quote
flyingrizzly Posted July 29, 2009 Author Posted July 29, 2009 Any closed shape can become a viewport. Draw out a circle, then type MVIEW and choose the "Object" option. Then just select the circle and it will become a viewport. Or you can use the "Convert Object to Viewport" button on the Viewports toolbar. I created a circle, typed "mview" and chose "object" option but it won't let me select the circle or the polygon I created. Am I skipping a step... Quote
StevenMc Posted July 29, 2009 Posted July 29, 2009 I created a circle, typed "mview" and chose "object" option but it won't let me select the circle or the polygon I created. Am I skipping a step... try the convert object to viewport. that should work. cant understand why the other isnt though Quote
flyingrizzly Posted July 29, 2009 Author Posted July 29, 2009 try the convert object to viewport. that should work.cant understand why the other isnt though I can't understand why it's not working either. I have attached a copy of the drawing I am working on. the scenario I am trying to create is in the blue rec on the bottom left. Quote
flyingrizzly Posted July 29, 2009 Author Posted July 29, 2009 i think you forgot to attach hehe I went to attach it, turned my head to answer the phone and thought it attached. Let me try it again. Okay, it wouldn't work the first time, the file was too large. Here it is again with just the single object I want to accomlish viewport.dwg Quote
StevenMc Posted July 29, 2009 Posted July 29, 2009 is this what you are looking for? if so i will describe what i did. viewport[1].dwg Quote
Cad64 Posted July 29, 2009 Posted July 29, 2009 You're not trying to do this in model space are you? I switched to one of your layouts, created a circle and used the procedure I described previously and it works fine. You just need to double click inside the circle and do a Zoom Extents. Oh, and make sure you're in paper space when you do this. I found that your title block border is a viewport and it was active. I deactivated it in order to create the viewport. Quote
Joseph Marquez Posted July 22, 2011 Posted July 22, 2011 So you cant create a viewport in a separate window? Quote
