I have drawn lines in the drawing but when I changed their thickness in line weight and print them it seems to be the same what do I do??
You could try using polylines and setting their Global Width to the required thickness in their properties.
Thank you, I have tried that as well I did not work out
What line thicknesses are being used?
What size sheet are you plotting to?
Do you have the lineweight set to a thickness in your plotstyle? If so, try changing it to 'use object lineweight'
I set this in my template by layer. Set it and forget it.
Attach your file so someone can see how you are trying to control line weight.
