CADuser20 Posted July 30, 2009 Posted July 30, 2009 Hi I'm having problems plotting with a new plotter. Typically if I have an entire sheet set I will select the first layout tab, shift and then the last and "publish the selected layouts" which works fine usually. But for whatever reason they come out scaled down and too small, almost to fit a smaller sheet size and get cutoff on the ends as well. I always thought that the batch plot grabs the settings from the page setups, and since it prints fine normally one by one it has me a bit baffled. Anyone have any idea how to rectify this? Thanks. Quote
StevenMc Posted July 30, 2009 Posted July 30, 2009 this link may be of use to you... http://www.cadtutor.net/forum/showthread.php?t=5075 Quote
Ryder76 Posted July 30, 2009 Posted July 30, 2009 Try this thread. http://www.cadtutor.net/forum/showthread.php?t=38795 The OP had a different problem, but the solution might work for you as well. Quote
