Squirrel Cottage Posted August 2, 2009 Posted August 2, 2009 Hi Team I trust you are all well and in good spirits. Have just installed AutoCAD 2009 and was wondering if any would be so kind let me how to ; 1/ Change the workspace / model background colour from white to black ? 2/ Instead of a new bank drawing page I would like the dialog box to be displayed so I can select an existing file or a template, when I start up AutoCAD ? 3/ where is the new drawing layout wizard, the one you use to set your own workspace ? Quote
rkmcswain Posted August 2, 2009 Posted August 2, 2009 1. Options > Display Tab > Colors Button 2. Type in STARTUP at the command line, set it to 1. 3. If you are talking about setting up a layout for plotting, then OPTIONS > DISPLAY tab > check ON the "Show Page Setup Manager for New Layouts" Quote
Squirrel Cottage Posted August 2, 2009 Author Posted August 2, 2009 Hi Super moderator Thank you for your help and advice it was most helpful. Quote
