Hi
I am a self taught Inventor user and recently embarked on an HNC CAD course.
In inventor when scaling a drawing 1:1 the printed drawing is the actual size of the component.
When using AutoCad, using view ports this alters the size of the printed component.
Is there some way to return the view to the correct printed scale.
It mayby the case that this is not normally required and am worried about nothing.
I only ask because the course asks for drawings in dwf format and if I submit a drawing in say 1:2 scale it will not measure corectly.
Thanks
James
In AutoCAD your objects are drawn full size in model space. Paper space is where you put your titleblock and border. It is also where you create your viewport(s). A viewport is like a window that allows you to see back into model space. The viewport is what is actually scaled. When you plot your layout it is done so at a scale of 1:1.
There it is hiding right in front of me "Viewport Scale".
AutoCad almost always has a simple solution if you know where to look.
Thanks for a speedy reply.
James
You're entirely welcomed James. Just happen to be passing through at the moment. If you have further questions you'll find plenty of friendly, helpful and knowledgeable people here at CT to guide you. I'm sure you'll be up to speed in no time.
