brianfalconer Posted August 10, 2009 Posted August 10, 2009 I have been trying to export a 3D CAD dwg to a 3D Studio (*.3ds) file. The CAD dwg is 6MB and the exported 3DS file is 216KB. Is this correct? it seems very small. Thanks for you help Brian Quote
StevenMc Posted August 10, 2009 Posted August 10, 2009 no need to double post Brian im sure someone with the knowledge will be with you soon. i'm guessing you posted it in the wrong section, if need be a moderator will move it. all the best -Steven Quote
brianfalconer Posted August 10, 2009 Author Posted August 10, 2009 Thanks, im only getting to grips with the system now. regards Brian Quote
NBC Posted August 10, 2009 Posted August 10, 2009 I was under the impression that 3DS Max could 'import' AutoCAD dwg files ? Quote
StevenMc Posted August 10, 2009 Posted August 10, 2009 it can. you might find the following link useful... http://www.caddigest.com/subjects/autocad/tutorials/select/081803_parsai_import_max.htm Quote
